Recently purchased an ASI224MC as an upgrade for the 120MC-S and have found out there's a huge learning curve for this camera. Can anyone make an suggestions for my settings listed below? Not sure if it's my FireCapture settings or just poor seeing/focus. I've recorded raw files (.ser ?) with FireCapture and debayered and stacked in AS2. Wavelets in Registax 6. The image will not sharpen at all in Registax. Moving the sliders only increases noise. I've included a very fuzzy image of Jupiter with the 224 and one of my better images with the 120. Thanks for your help.
FireCapture v2.4 Settings
Camera=ZWO ASI224MC
Filter=L
Profile=Jupiter
Diameter=37.99"
Magnitude=-2.10
CMI=9.8° CMII=13.2° CMIII=50.4° (during mid of capture)
FocalLength=7400mm
Resolution=0.17"
Filename=Jup_222506.ser
Date=240516
Start=222506.060
Mid=222536.062
End=222606.065
Start(UT)=022506.060
Mid(UT)=022536.062
End(UT)=022606.065
Duration=60.005s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT -5h
Frames captured=4754
File type=SER
Binning=no
ROI=1024x768
ROI(Offset)=76x32
FPS (avg.)=79
Shutter=7.864ms
Gain=322
Brightness=1
AutoExposure=off
Gamma=50
SoftwareGain=10 (off)
