I have the driver 2.7.3.21 on w10 with a usb2 model asi120mm. It works fine in phd2 and firecapture when using a usb2 socket but the same camera is not recognised on the same laptop when plugged into a usb3 socket.
I need to upgrade my laptop and the model I have in mind has only usb3. Is there a fix to make the camera recognised on usb3?
TIA
I think the problem should be error code 10?
have a look at here:
https://astronomy-imaging-camera.com/manuals/Trouble%20Shooting.pdf
you can try to update the compitable firmware
Sam
Thanks. That did it. It now works with both usb2 and usb3:)
Cheers,
Steve
