I'm having some problems using an ASI 120MM camera with the ASCOM driver and Prism Astro software (my purpose is to make an allsky camera). I've seen in a previous post that one of these problems have been addressed (http://zwoug.org/viewtopic.php?f=17&t=2261). I found the same workaround (take two successive exposures) and the driver you provided in this post fixed the issue. However, it seems that with the latest drivers, the problem happens again.
Another problem I have is that the image is sometimes split in two parts. Part of the image on one side is moved to the other side of the image. You can see one image here :
http://asteroide06.fr/20160617_0_47.jpg
I'm using the ASCOM driver version 1.0.1.21 and Windows 7 64 bits, ASCOM platform 6 SP3.
Thanks in advance for your help
Jean-Marc
