Hello,
I received my ASI1600MM-Cool a while ago and have been doing some initial testing. Otherwise the camera looks very promising but I noticed that the bias frame exhibits random horizontal banding when the TEC is on. Their location is random in each frame so they cannot be calibrated out, and their intensity varies directly with the current TEC power (%). When the TEC is turned off the banding vanishes completely.
I have the latest software versions (driver v1.3.5.20, ASCOM v1.2.0.9) and have tried using a different power supply etc.
Here is a sample of the problem:
And here are download links for single bias frames with TEC at 80% and off (at the same sensor temperature).
https://www.dropbox.com/s/rx98iohx8i1g9l9/ASI1600%20-20c%20TEC%2080%25.fit?dl=1
https://www.dropbox.com/s/mh672t6n331uu5o/ASI1600%20-20c%20TEC%20OFF.fit?dl=1
I haven't heard reports of this behaviour from other users so I figured that something could be wrong. Any suggestions?
Best Regards,
++ Jari
