Sam,
I plan to purchase the mini-EFW for the 1600, when you put it up for sale this month. I plan to buy the high quality 1.25 inch Astrodon filters for it. They offer two types for LRGB - E-Series and I-Series. As you can see from the attachments, the only difference is that the E-series blocks some of the lower end of the red spectrum.
Here are the descriptions:
I-Series filters are designed to approximately equalize the flux of Interline CCD detectors (formerly Kodak), including compensation for the solar photon flux. The I-Series filters compensate for the lower red response of these Interline detectors affecting the design of the Green and Red filters.
E-Series filters are designed to approximately equalize the flux of red-sensitive full-frame (formerly Kodak E-Series) CCD detectors, including compensation for the solar photon flux. This means that your RGB color combine weights will be approximately 1 within perhaps 10% for equal length exposures.
Which series would be most appropriate for use with the ZWO ASI1600MM camera?
Thanks,
Gary
