Sam,
You have said that the unit will handle 31mm filters (in addition to 1.25"). I am leaning towards the 31mm size to reduce the possibility of vignetting. Two questions:
1. Will one carousel fit either 1.25" or 31mm filters, or is there a need to purchase separate carousels for both sizes?
2. The only option that I can find for 31mm filters is for "31mm rings". Does the 31mm size need to be completely unmounted, or is it OK for them to be mounted in a ring?
Thanks,
Gary
