The fan in my ASI 1600MM-C is always running whenever the power and USB cables are plugged in, even if I am not actively taking pictures. Is this normal?
Yes, the TEC is keeping a constant temperature.
the fan is powered if you plugin the external 12V power supply
Thanks, Sam.
