Hello,
i am using the asi1600mm-c with astro photography tool (APT) and the ascom driver. APT has
a "settings" button which opens the ASCOM Settings Dialog. If the Settings button was pressed a warning Dialog Comes up that warns that the camera has to be temporary disconnected.
In result of this disconnection it leads to a stop of the camera cooling. So i can't easily try different gain Settings without an abrupt increase of the camera temperature and risk of thermal shock. My QHY9 camera holds the current (setted) temperature in this Scenario.
Is this a "Problem" of the ASCOM Driver, or should i contact APT?
Best regards,
Christian
