Hi,
We are trying to use a ASI 178MC to record aerial videos (camera is installed in an aircraft). We tried to use it as a Directshow camera and record videos using codecs like wmv or mp4 codecs in order to reduce size comparing to raw videos using firecapture or similar software. But most software doesn't recognise it or crash when selecting it. VLC crashes. VirtualDub refuses to capture indicating that frame rate output from the camera is not regular.
USB3camera (installed with ASI driver) can record compressed WMV video, but the result is strange (videos are too slow or too fast, and indicates a lot of dropped frames).
What software do you recommend to use for that (recording videos with 178MC camera with a "classic" compression like mp4).
Thanks a lot for your answer.
