Hello everybody,
my Name is Svend.
I´m 47 years old. I´m from northern Germany and the new one here : .
Since half a year I own an ASI120 MC Version V1.6. (What means with USB 2.0 and ST4 port.)
To install a temperature sensor for an external cooling system (yes I know...haha...another one ) at the inside, I need to get the hole pcb out of the cam shell.
Open the housing and loosen the four screws that hold on the pcb is/was not the Problem.
In older Versions without ST4 port nothing more was to do, the pcb could be taken now.
But since this newer Version additional has a ST4 port mounted 90° to the USB port, I can´t find out how I can get it out. Is there a trick? How do ZWO get the pcb out? (for example for a repair)
To be serious...how did ZWO get it in?
Has anyone an idea?
Greats & CS
Svend
