Sam and others can you tell me which power supply I need for the New ASI 1600MC-Cool (color)(USB) I did not see one on the ZWO sight .. would this power supply work.?
12 Volt Power Supply - 2.5 Amp Standard (12V 2.5A DC) Adapter (USA)
Thank You
Al Bates (USA)
Looks ok. You can also check for a similar rated for more amps.
AL Bates wrote:Sam and others can you tell me which power supply I need for the New ASI 1600MC-Cool (color)(USB) I did not see one on the ZWO sight .. would this power supply work.? 12 Volt Power Supply - 2.5 Amp Standard (12V 2.5A DC) Adapter (USA) Thank You Al Bates (USA)
Interesting, the camera did not come with a Power Supply?
rockstarbill wrote:AL Bates wrote:Sam and others can you tell me which power supply I need for the New ASI 1600MC-Cool (color)(USB) I did not see one on the ZWO sight .. would this power supply work.? 12 Volt Power Supply - 2.5 Amp Standard (12V 2.5A DC) Adapter (USA) Thank You Al Bates (USA) Interesting, the camera did not come with a Power Supply?
No.. the New ASI 1600MC-Cool (color)(USB) dose not come with a power supply. Not yet anyways.
I use a Kendricks 5A Quad power pack (34mAhr) that seems to work very well.
Also have a lighter duty Celestron Powertank which works too.
we would recommend 12V and more than 3A
Sam wrote:we would recommend 12V and more than 3A
Is that the same for the ASI 1600MM-Cool as well?
rockstarbill wrote:Sam wrote:we would recommend 12V and more than 3A Is that the same for the ASI 1600MM-Cool as well?
The ZWO website user manual in the following link says its 2amp max??
https://astronomy-imaging-camera.com/manuals/ZWO_ASI_Cooled_Cameras.pdf
The ZWO website link for the ASI 1600 says 2.5 amp here
https://astronomy-imaging-camera.com/products/asi-cooled-cameras/asi1600mm-cool/
It says 12v - 2amp on the back of the ASI 1600MM as well
I'm a bit confused as to the amp requirement
David
yes, the power consumption of our cooled cameras are nearly the same
2A is the max current it need
but you'd better choose an AC-DC adapter can provide more than 2A current
