I'm setting up an ASI 174MM for solar imaging, using a spectroheliograph.
This means using an ROI of around 1920 x 48 pixel and obtaining the highest possible frame rate. The trials so far show the frame rate is OK - around 600fps but I'm still having "problems" with the ROI and/or Cut-out features of FireCapture.
The frame rate is much slower when the Cut-Out feature is selected....and using the commands given (Ctrl+drag to move) I can't get it to reposition on the image!
The reduced ROI option gives fantastic frame rates, but the "Shift+Arrows to move" doesn't seem to work - it increases the size of the ROI!!
I need to be able to reposition the ROI on the screen to match the spectral image.
Can someone/ anyone with more experience with FireCapture help me???
