Hello,
I noticed that the temperature of the sensor is about 4 to 5 °C under the ambiant.
Is the conversion mV to °C right ?
It means, if the offset is constant, that a -10°C means -5°C.
Am I right ?
the temperature should be very accurate
it's below ambient then means the sensor is below ambient
it will go up if you run the camera
