Hello Sam, i tested the cam last friday on MAC OS - AstroLive USB and on Parallels Win 7 with APT 3.1.3. , Both programms crashed unexpected at different points of work most in combination with changing binning . I red that it is neccessary for ASI 1600 users to work with ascom driver 1.0.2.5. ?
But in Astrolive i cannot found any explanation ? .
Similar problem on windows subnotebook with APT there after installation Ascom 6.2 and newest zwo drivers for ASI cams APT cannot found the cam ?? In the devicemanager the cam is properly installed .
Same problem in Astrolive but found the cam and crashed . Sharpcap newest version under windows 2.9xxx works. I think here is a cameradriver problem at all ?
Any suggestions ? , i hope you have a good idea ; )
P.S. donetframework is version 4 - i must upgrade in the subnetbook to 4.5. ???
Best wishes Rainer
