Hi Sam
I tried this sequence again. Plugged both camera's in the usb hub and connected the Hub o the laptop.Started PHd and selected the 120 and connected it.Took a test frame and verified it worked.Then Open SGP and opend the asi ascom dialog and selected the 178 and connected it.This time it seemed to work.However the same sequence the previous night accepted the selection of the 178 but when I tried to take a test frame i got stuck downloading .When I went back to the ascom dialog it was now somehow back to the 120.
It was like the laptop got confused between the two camera and although I selected the 178 it somehow was trying to connect to the 120.
I realize this is now tricky since I cant seem to reproduce the error, seem like the shut down over night seemed to resolve it.
I am planning another imaging session in the next night or tow weather permitting then I will test again.
