Hello, can anyone assist in regards to operating the filter wheel? At present the only way I have found to operate is by opening Altair capture program select settings to choose a filter then close it down. is there a way to use the filter in stand alone?
Thanks
Jim
you need software which can control the EFW through ASCOM
such like SharpCap or Firecapture all support it too
I have written a windows program that will control a ASCOM filter wheel, you can find it
at http://wrastro.com/files/Filter_Wheel_Control.zip
Hope this helps.
Thank you for your guidance, sharpcap does work well and I will try your program as well.
Sorry for the delay in responding to your useful advice
wruser wrote:I have written a windows program that will control a ASCOM filter wheel, you can find it at http://wrastro.com/files/Filter_Wheel_Control.zip Hope this helps.
wruser I just downloaded and tried your filter wheel control and it works great Thank You for spending your time on this!
Sent from my iPhone using Tapatalk
