Hi Sam
I had to uninstall all. Installed first camera driver from zwo site, and opening sharp cap suddenly fan started to work...
Then I installed ASCOM 6.2 and latest ascom driver, and the problem now is that I have no image either with Sharp cap, amcap or firecapture. Sometimes the image is black, sometimes white with some grey and white "squares" pattern on the top of the image.
When I install all drivers, the first time I connect the camera through usb 3.0 everything seems to be ok, but there is no image, but if I disconnect the camera and connect it again, my laptop doesn't recognize the camera, or tells me that usb has overpassed speed limit.
I guess the root cause is my new laptop with Windows 10. With my asi 120 had similar problem. I used it with my old computer with win xp several times and always worked ok, but when I buyed the new pc, 120 started giving me problems at high resolutions, connection cuts...Slightly resolved with the upgrading tool...
Any idea? This is frustating in so many ways...
Thanks Sam
