Hi,
Need some help guys.
System info:
-Raspberry Pi 3
-Raspbian GNU/Linux 8 (Jessie) - 2016-09-23
-SDK ASI_linux_mac_SDK_V0.4.0929 and ASI_linux_mac_SDK_V0.3.0727
-ASI20MC
Problem:
-Starting an exposure with ASIStartExposure some times aborts the program with the "Segmentation fault" error or ASIGetExpStatus just keeps returning ASI_EXP_WORKING and them the program hangs, ASIGetDataAfterExp never even gets called.
Consideration:
-With either SDK (4.0929 and 3.0727) the camera is recognized, I can open the camera, list its attributes, set its properties.
- I have taken in consideration the need to call ASIInitCamera depending on the SDK version.
- I have tried with other programs (oaCapture, Lin-guider, ASI demos, etc) and the result is the same "Segmentation fault" error or the program just hangs after an exposure/capture is initiated.
- I have used every version of libASICamera2.so that is available.
- I have set max_usb_current=1 in /boot/config.txt to allow more Amps on the USB ports
So, what the heck i'm doing wrong ? Any other reports of the same problem on the Pi 3 ?
Best regards,
PA
