Hi All,
I wanted to measure shutter latency in my ASI 1600MM-Cool. I used tool provided with MaximDL. I expected that the value will be very low but it looks like shutter latency is around 0.7 seconds. I just wanted confirm that what I red is ok and did not make any mistake. Do you have similar times?
Thank you!
Zoch-Ol
I think it's reasonable if you test with one USB2.0 cable and run at 16bit format
because the camera can run at 1fps under such condition
you can try to connect the camera to USB3.0 host to get a shorter latency
