Hi ZWO,
The back focus on the ZWO ASI 1600 is quoted as 6.5mm. And its shown as a physical dimension on the drawings.
When working out the correct spacers for my focal reducer I need to add 0.7nm for the optical path difference caused by the glass thickness of my filters.
Do I need to add anything for the optical path difference caused by the thickness of the protective window on the camera? Is the 6.5mm figure a true optical path length, or a physical path length?
If the 6.5mm is a physical distance, then can you tell me the thickness of the protective window please.
Apologies if this has been asked before.
Regards
BorgBoy
