Sam wrote:
"compatibility" firmware is only used to fix the problem host doesnot recongize it
the old firmware has the best performance, so please flash it back and feed back
I tried to flash the original firmware and then the camera does not work with the RPi at all. I tried to take an exposure from the shell, using indi_setprop, and take an exposure from PixInsight, but both exposures failed. This is the output from indiserver when PixInsight was taking an exposure:
pi@observatory:~ $ indiserver indi_asi_ccd
2016-12-29T12: startup: indiserver indi_asi_ccd
2016-12-29T12: Driver indi_asi_ccd: recorder: setpixelformat 1195528775
2016-12-29T12: Driver indi_asi_ccd: recorder: setsize 1280x960
2016-12-29T12: Driver indi_asi_ccd: stderr EOF
2016-12-29T12: Driver indi_asi_ccd: restart #1
Child process 4285 died
2016-12-29T12: select(9): Interrupted system call
2016-12-29T12: good bye
Now, back to the compatibility firmware to make it work again.
