@riklaunim
As it is not possible to have the hand on the SDK it is not possible to compile the code to align ARM device with INTEL devices.
And I am not sure that it is a less attention to those devices. I hope this is a much more unfortunate choice. I hope it will be fixed some day. Meanwhile I will try to be aware and use bypasses.
@Sam
Hello Sam,
My problem is the following one:
The sensor on the 178MM is a 3096x2080 pixels size.
With the linux drivers used with INDI/EKOS/KSTARS on INTEL platform the displayed resolution is the right one 3096x2080.
With the drivers for ARM device (ODROID-XU4) the displayed resolution is 3072x2080. If I try to push the width to 3096, I can't. A message is diplayed telling that 3072 is the max value (like this value is hard coded).
The result is that the previous work done on INTEL device (darks, flats, etc..) are not consistent with the picture taken in remote with the 178MM connected to a ARM device. The following result is that pre-processing crashes when trying to use pictures with different resolutions.
Regards
Patrick
