Hi all,
Found an older thread on the topic. (http://zwoug.org/viewtopic.php?f=21&t=1973&p=3950)
New stuff, new guys, modified questions:
Anyone tried the ASI290MM with ZWO ADC (got both just now) and a Baader U filter?
http://www.baader-planetarium.com/en/filters/planetary/special-filters/baader-u-filter-(venus-and-uv---350nm).html
Btw I believe this is still only UV-pass filter around, for amateur astronomers.
Is the protective window of current cameras (the 290) still of a type that should be removed (temporarily) for doing UV?
I should also add that I'm using a C11HD, and preferably also my BPFFC barlow (Baader Fluorite Flatfield Converter).
Not just mirrors in these SCTs (both corrector glass in front and flattening elements in the baffle tube), and I can't even find anything on the supposedly beneficial fluorite elements, regarding UV-pass of the coatings.
I'm also looking for a sensitivity curve of the ASI290MM. There's apparently no dedicated manual to be downloaded, and the product page does not show how fast the curve drops below 400nm.
Any help on any of this would be much appreciated.
