Hi,
What’s the thickness of the glass?
And height, threads/total?
That is, will it fit in EFW/EFWmini? ("threads length shorter than 3mm, height without threads less than 7mm")
Thanks.
our filter of couse suitable for our EFW
the total height is 7mm only
Hi, got one now.
I measured filter threads to 2,5mm, filter height without threads 5,0mm. So, mine is totally 7,5mm, which is also well within.
Still, would like to know the glass thickness. (harder to measure safely!)
thickness should be 2mm
