I'm trying to put together a portable imaging setup and just received my ASI1600MC-C. Are the USB 5V Ground and the 12V Ground connected or isolated? If isolated I should be able to use different supplies w/o worrying about ground loops.
the USB5V and 12V ground is connected together
Thanks Sam. I kind of figured they would be. I've already got plans for a single supply solution so it's not a problem going forward.
