Hello.
Currently I have a telescope c9.25 and wanted to buy a camera for planetary, lunar and something of DSO. That camera I recommend in color?
Thank you.
ASI290MM or ASI178MM if mono, ASI224 if color camera. DS imaging is a different story as those cameras have small pixels plus SCT has a very long focal length. (plus accessories).
Between 224mc and 290mc which is best for me?
What is more sensitive?
For planetary nebulae which is better?
Color 224 or color 290 are very similar. Can't say that there is a clear difference between them. You can compare charts on both product pages.
With the camera 290mc is may use the filter IR 850nm or not is very sensitive to the IR? I do not see the filter as recommended accessory.
you can use 290mc if you need larger resolution
What kind of camera do you want? The budget?
Something like here would work well
