The flange to focal distance (flange to sensor) of the canon EF mount is 44mm.
For this camera, it is 17.5mm, so you'll need an adapter (and maybe spacers/thread adapters) that makeup the difference, or 26.5 mm.
Although I have this camera, I haven't tried it yet with Canon lenses but do have a fotodiox pro eos-c adapter I have used with other cameras. It is the right size (if threaded all the way in) in terms of depth.
However what you need for this camera is a T-mount, so you want and EF mount to T mount setup, that is 26.5 MM long.
Hmmm, looks like ZWO actually makes what you need (silly me):
http://www.highpointscientific.com/zwo-t2-to-eos-adapter-for-all-asi-cameras-eos-t2?utm_source=google&utm_medium=cse&utm_term=ZWO-EOS-T2
