Hi!
I am wondering which ZWO camera have the best UV sensibility (300-400nm).
So far I found that the ASI178 could be the best choice (is there a great sensibility difference bewteen color and monochrome?).
Your thought?
best.
Color sensors are nearly blind to UV so you need a mono sensor. Sensitivity can only be estimated as no official 300-400 nm measurements are available from what I saw. 178 and 290 are the currently leading sensors. More than sensitivity low noise is the key factor here (as sensitivity is pretty much constant among few last generations).
