I am having a problem with SGP (ASCOM) but not with Sharpcap.
I setup a sequence to take 100 frames and I got to about frame 62 before things appeared to be stuck on 'Downloading'. However when I looked at the file system I could see the file size growing for the current frame, but very very slowly. It took about 20 minutes for one frame to finish.
I rebooted and the speed looked fine so I started the 100 frames again. Again the same problem occured with very slow download speeds for later images. The first 10-20 which I watched manually worked fine.
I have SGP logs for the issue. Near the end you can see it took 500,000ms for the last frame to complete while all of the previous ones took ~20,000ms: https://drive.google.com/open?id=0B_jRsujhCGrWSXUxV0NWWk0yckk
Is there any ASI/ASCOM logs I can capture to help?
System Config:
SGP version: v2.5.1.17
ASI Ascom Version 1.0.2.23
ASI camera drivers 1.3.12.28
USB Setting: 40
USB 3 & 2
Intel Compute Stick
I did not power or run the cooler for these experiments
