Hi!
Has anybody have a solution for the ZWO ASI120MM usb2.0 unreliability issue which makes it go to black with ALL apps after a while. The ONLY way to recover is to physically unplug and then plug the USB camera back in.
Rebooting doesn't help, re installing the driver doesn't work, going to the device driver and making sure the USB AND the driver USB power management "Allow computer to turn off the device to save power" unchecking will not work. Same problem with windows 7 pro, 8 and 10...
Basically the camera will work famously for half a day (I'm using it as an all sky camera) and then it will go to black..it will still show that it's capturing but no video, nothing.
I've turned off the USB turbo to minimum ,maximum, in between,,nothing..I have to physically remove power to it by unplugging it and then plugging it back in and presto.
I've lowered the usb setting to 40 increased it to 100, added a powered usb hub in between and then I added an active, high quality usb cable to no avail, same issue...the only thing that will fix it for a while is to physically unplug the camera and then plug it back in. rebooting the computer won't do it, power has to be removed from the camera completely...
Very inconvenient since It's for my remote Observatory.
Thoughts?
best!
Pablo Lewin
