Hello,
when i don't use dithering i have a strange pattern in my pictures:
(extremly stretched to show the pattern)
After furter inspection i noticed that this pattern is also in my flats:
(background extracted with ABE in PI and also stretched)
It makes no difference which filter is used, or if i use my newton or the refractor.
I use a led box to generate the flats and very short exposures (for example 0.002s for L)
to generate the flats, but as the pattern is also in the lights that can't be the reason.
So where comes the pattern from? Could this realy be from the wafer saw and the polisher
as an astronomy friend of mine assumed?
Thanks and best regards
Christian
