Hi,
I have ordered a Asi071MC cooled and I would like to know how to power the cooling systems when outside in the field.
What battery I can use and how to connect ?
Thank you very much
Christian
you can use 12V battery
9-15V all can power up the cooler
I will also be using my ASI294MC_Pro in the field and will try to power it with a 9v battery. My question is, as the battery dies, the power will drop below 9v, will this harm the cooler, or will it just stop working?
maxchess wrote: Hi, I will also be using my ASI294MC_Pro in the field and will try to power it with a 9v battery. My question is, as the battery dies, the power will drop below 9v, will this harm the cooler, or will it just stop working?
It will not harm the cooler.
