Hello:
How can the ASIGetExpStatus failed be resolved on RPI3 using Ekos and INDI server?
It was suggested to update to the 120mm-c compatible version using the windows tool. Please help resolve this.
I have been using Ekos successfully with a Canon T6i on my RPI3. It does not matter if the indiserver is running remote on RPI3 - 127.0.0.1 - or local to Ekos.
Running local though, the ASI1600 hub does not find the ASI EFW. Running indiserver remote on RPI3 the ASI EFW is found.
Using a new ASI1600MM-C v3 I am unable to get a single frame, whether it is a preview or scheduled.
Debug is turned on the ASI1600 and an excerpt is of the log follows.
Excerpt:
INFO 5.202128 sec : Session log file /home/pi/.indi/logs/2017-01-21/indi_asi_ccd/indi_asi_ccd_22:$
INFO 5.202262 sec : Upload settings set to client only.
DEBUG 5.202442 sec : Requested CCD Frame is ( 0, 0) (4656 x 3520)
DEBUG 5.202492 sec : UpdateCCDFrame ASISetROIFormat (4656x3520, bin 1, type 0)
DEBUG 5.255528 sec : Setting frame buffer size to 16389120 bytes.
DEBUG 5.255730 sec : UpdateCCDFrame ASISetROIFormat (4656x3520, bin 1, type 0)
DEBUG 5.246331 sec : Setting frame buffer size to 16389120 bytes.
DEBUG 5.246526 sec : UpdateCCDFrame ASISetROIFormat (4656x3520, bin 1, type 0)
DEBUG 5.299397 sec : Setting frame buffer size to 16389120 bytes.
DEBUG 5.299629 sec : UpdateCCDFrame ASISetROIFormat (4656x3520, bin 1, type 2)
DEBUG 5.290327 sec : Setting frame buffer size to 16389120 bytes.
DEBUG 5.290556 sec : UpdateCCDFrame ASISetROIFormat (4656x3520, bin 1, type 2)
DEBUG 5.390950 sec : Setting frame buffer size to 32778240 bytes.
WARNING 5.391542 sec : 16 bit bayer format GRBG it not supported by the SER recorder.
DEBUG 5.391898 sec : Configuration successfully loaded.
DEBUG 5.384632 sec : Setting frame buffer size to 32778240 bytes.
WARNING 5.384728 sec : 16 bit bayer format GRBG it not supported by the SER recorder.
DEBUG 5.384918 sec : Configuration successfully loaded.
WARNING 6.432385 sec : World Coordinate System is enabled. CCD rotation must be set either manually or $
WARNING 6.455092 sec : World Coordinate System is enabled. CCD rotation must be set either manually or $
DEBUG 41.941423 sec : StartExposure->setexp : 10.000s
DEBUG 41.920465 sec : StartExposure->setexp : 10.000s
INFO 41.948078 sec : Taking a 10 seconds frame...
INFO 42.101601 sec : Taking a 10 seconds frame...
DEBUG 52.371764 sec : ASIGetExpStatus failed (0). Restarting exposure...
DEBUG 52.472024 sec : StartExposure->setexp : 10.000s
INFO 52.472308 sec : Taking a 10 seconds frame...
DEBUG 52.685237 sec : ASIGetExpStatus failed (0). Restarting exposure...
DEBUG 52.785550 sec : StartExposure->setexp : 10.000s
INFO 52.785859 sec : Taking a 10 seconds frame...
DEBUG 62.765265 sec : ASIGetExpStatus failed (0). Restarting exposure...
DEBUG 62.865561 sec : StartExposure->setexp : 10.000s
INFO 62.865829 sec : Taking a 10 seconds frame...
DEBUG 66.170600 sec : ASIGetExpStatus failed (0). Restarting exposure...
DEBUG 66.270935 sec : StartExposure->setexp : 10.000s
INFO 66.271203 sec : Taking a 10 seconds frame...
ERROR 73.122929 sec : Exposure failed after 3 attempts.
