Hello,
I have 2 questions:
1) I just received my ASI 1600 from Robtics (NL) and noticed that there is sadly a big dust mote on the sensor...
See this image for the dust mote: https://i.imgur.com/8xnxXjZ.png
Is it safe to open the sensor chamber with the 4 screws on the outside of the body and blow off the dust with a hand blower?
2) I also bought the OAG and EFW (8x31mm) and wonder what is the correct order / way to connect everything to achieve 55mm backfocus. Is there a manual? The current manual only shows connection without OAG.
So far I have:
sensor (6.5mm) camera-front - directly screwed into FW (20mm) FW female T2 -- OAG screwed into (16.5mm) end of OAG is either male M42 or male M48 ...... (this is what is missing) ...... M48 male from reducer (55mm backfocus)
So I would need a ~10mm M48/M42 to M48 (both sides female), right? Anyone knows where to get one of these?
Regards,
Denis
