don't know this cable, read the doc and saw
- 5Gbps seems fine for USB3 so rely on this
1 x USB 3.0 Type A Host Connector
1 x USB 3.0 Type A Power Connector (required for devices drawing more than 2.5W)
Equipments should be compatible with AIA USB3 Vision (don't know the specs)
http://www.visiononline.org/vision-standards-details.cfm?id=167&type=11
Theory :
Long cable eats a bit current (by EM radiation, heat...), this is mainly square-root frequency dependant, diminishing amplitude especially at high frequency wave. Something like 0.4dB/meter @ 1Ghz for standard PVC coaxial cable, not much indeed, but for TV cable : signal amplificator are used.
No reason that this USB3 cable don't loose power along his length.
https://www.st-andrews.ac.uk/~www_pa/Scots_Guide/audio/part7/page1.html
In electronic RS422/RS485° specs used current driven amps to stabilize signal strength (wave form)
http://www.ti.com/lit/an/slla070d/slla070d.pdf
Cable length brings also delay, but USB3 allow asynchronous transmission, higher rate may be limitated by the handshake (acknowlegde of frames) during exchange.
°old protocol...
As a last test :
- try to borrow a usb hub and plug the second connector (Power Connector) to get more current
- at first configure exchange speed (USB rate) at minimal, increase if it works.
That's all that comes in mind to help.
Myriam
