I have an AIS120MC which I received recently for Christmas. I can see color images using AMCAP but I only get gray images using Firecapture. Everything seems to be set appropriately in Firecapture. I do notice that Fireacpture will not allow me to select debayer. The historogram only shows a single color. Here is a printout of a text.txt, and as you can see the filter is set to L:
FireCapture v2.5 Settings
Camera=ZWO ASI120MC
Filter=L
Profile=test
Filename=test_21_50_22.avi
Date=29_01_17
Start=21_50_11.242
Mid=21_50_22.156
End=21_50_33.071
Start(UT)=03_50_11.242
Mid(UT)=03_50_22.156
End(UT)=03_50_33.071
Duration=21.829s
Date_format=dd_MM_yy
Time_format=HH_mm_ss
LT=UT -6h
Frames captured=398
File type=AVI
Extended AVI mode=true
Compressed AVI=false
Binning=no
ROI=1280x960
ROI(Offset)=0x0
FPS (avg.)=18
Shutter=4.455ms
Gain=76 (76%)
WRed=50
HighSpeed=off
Brightness=2
Gamma=50 (off)
AutoExposure=off
SoftwareGain=10 (off)
AutoHisto=75 (off)
WBlue=90
USBTraffic=80
Histogramm(min)=0
Histogramm(max)=255
Histogramm=100%
Noise(avg.deviation)=n/a
Limit=none
Sensor temperature=29.8 °C
There must be a simple Firecapture setting that I am missing. Any help would be appreciated.
