Hi
just taken delivery of a replacement ASI1600 and began by taking bias subs for the library. I took and stacked 300 subs using the standard Pixinsight integration tool. The subs were Gain150 offset 21 and the fastest camera speed of .000032, I also did some with an exposure of .001.
I have attached a copy of the master Bias produced from the 300 subs. AS you can see this is splattered with black pixels and very little in the way of banding. Any ideas if there is something wrong with the master bias or is this normal
I have also attached the superbias although I understand that the current wisdom is not to use this as the banding of these types of chip are not all in the same direction (whatever that means!)
Sam comments on the black pixels would be appreciated
Thanks
