I have an ASI174mm and imaging the moon, when I check 16 bit in Firecapture the screen goes black.
The camera is supposed to give 12 bit but Firecapture only gives 8 bit unless 16 bit is checked.
I also have the ASI290 and this will give me 16 bit in Firecapture.
Is there a problem with the 174mm (defect) or is it normal ?
I've had it since April and have talked to Highpoint Scientific about this in the early days but never got a good answer.
Only when I more recently got the ASI290mm did I realize that 16 bit was possible in Firecapture.
Can someone give their ASI174mm experience with this ?
Thank You,
Gene
