Hi,
Last year I had my ASI120MC working well with my RPi2 via USB. Since then I had no time to work on my gear. Now I restarted and bought a RPi 3.
I use INDILIB and Kstars but the Camera does not connect or gives a sign of life.
Under Win10 it all works fine via ASICAP.
From Jasem on INDILIB forum I read that I should flash the firmware of the ZWO.
I downloaded the firmware via the Win tool that reported the firmware was updated. Under Linux still no possibility to connect to the camera.
I saw on the forum also that a tarball was made available to flash the firmware in Linux but this does work according to what I see.
Could someone give me a hint please? I am a bit embarrassed when asking because I am sure the problem has been solved but I do not immediately find on the web the way forward.
Thanks in advance,
Stefan
