Thank you very much for the prompt update.
I've tried the driver - two things:
a) The settings still don't seem to be persistent (at least the USB bandwidth is not, which is the one I tried and need to change regularly). I've looked at the descriptions in the driver - they only really tell you the name, not what it really does, nor give you any advice on how you might want to adjust the settings.
b) The activate relays is now working - when I press the camera relay buttons on the take photo tab, the scope moves as expected. However, there is a problem in the guide calibration routine. When I try this, TSX takes the initial photo, then starts to move the mount at the guide rate as expected. At this point, it should wait for the calibration move to complete (it guides the mount for the time you set, say 30s, then takes another image to calibrate how far its moved). However, TSX immediately takes another photo and says that the mount has not moved far enough. In the meantime, the mount continues to move at the guide rate but indefinitely.
I wondered if TSX expects this to be a synchronous action (i.e. its waiting for the guide to finish), but you have set it up to be asynchronous? Either way, there is a problem with the calibration routine (which is kind of vital to be able to guide :) ).
Happy to test out another version if needed.
Thank you very much,
Colin
