I got a LS80 and am trying to use my ASI174MM and ASI120MM-S
I haven't had that much time to play with the LS80 yet, it has been in the low 20's and winds 20-30 mph, if it is cloudy it is warm and no wind, clear cold and windy!!
Anyhow i threw a Meade shorty 3x Barlow on the B1800 with the ASI 174mm I get NR but they are large, I had 5 on this shot, but what bothers me is the very fine lines, almost like I printed it on textured paper or it was the noise pattern on a TV
Some said it is a Bayer Matrix but it is a mono camera. You cannot see the lines until you process the AVI
Since it is on both camera's I can't see how it is the cameras, I used the same cable on them, could it be the cable that ZWO provides with the camera, but they have been working well with other HA scopes
for examples of the good captures see https://www.flickr.com/photos/jmpadell/
