I am in need of a coma corrector and am considering the Baader Planetarium 2" Mark III Multi Purpose Coma Corrector. The MPCC requires that you get 55 mm from the sensor to the back plane of the MPCC III.
I am not quite sure how to measure this. My current setup is using 1600MM Cool and the Electronic Filter Wheel mini. They are connected to a LXD75 SN8 (running at f4 (812x203)). I am assuming you attach the MPCC after the EFW in the train. I am not sure what or how much in spacers I need to get to the 55 mm required distance (as I am not sure how much is the total in the 1600MM with the EFW attached). For example, I know the BF of the camera is 6.5mm, but I do not know what the EFW adds and if you have to add the ZWO filter thickness. I would appreciate if you guys can tell me what the starting point is with the camera (and even possibly what spacers I need to get to the 55mm distance).
Thanks
Kaos
