I just got this camera and the initial tests look great. I am waiting on a coma corrector and was trying to figure out the flat wizard in SGP. I am using a Gerd-Neuman FP to produce my flats. The SGP manual states that "Target mean: This indicates the ADU that you would like to obtain for your flats. For CCDs this value is generally between 20,000 and 40,000. Ideally you want to your flat data to fall in the area where your CCD behaves in a linear manner. You man need to consult your CCD manufacturer to obtain this information, but typically CCDs behave linearly under 40,000 ADU." Since this is a CMOS camera I am not sure what value to enter in the parameter section. Based on the histogram on test images, it looks like the CMOS data is converted into ADUs but I am not sure about this.
Any input into what the parameters in the attached dialog box should be for this camera would be greatly appreciated.
Thanks
Kaos
