Hi - there are two separate issues.
One is related to getting the X2 driver (software that allows your cameras to work with The Sky X from Software Bisque) to work properly on the Raspberry Pi - currently there are timeouts every few minutes - see this thread.
http://zwoug.org/viewtopic.php?f=17&t=6862&start=10
The second is more fundamental - as I described in my post, the connection from the OAG to the guide camera is on a stalk, fixed to the main body of the OAG via two thumbscrews.
Unfortunately, with this design, it allows movement perpendicular to the thumbscrews (~ 1mm). I haven't had the chance to use this yet, but I would anticipate that this will cause differential flexure between the guidecamera and the main camera, which will mean that the guider will not do a good job keeping the mount pointing to the right position - I might be wrong, but I've had previous experience of this even when the connection appeared to be absolutely rock solid.
If the weather ever improves here in the UK, I'll gather some data to investigate.
It is possible I've missed someway to remove this movement - I'm sure you have tested this out too - if so, it would be great to know.
Thank you,
Colin
