yang wrote:the driver updating of  V2.0.1.3 only impacts ASI120S and other USB2.0 cameras, you should use the latest Sharpcap, Firecapture and OpenPHD to support this new driver if you use ASI120S and USB2.0 cameras
Thank you for the reply.
Perhaps I wasn't clear. I use the very latest versions of SharpCap. I installed the ZWO driver pack. The problem appeared. I upgraded to the current version of PHD2 and the problem does not occur if PHD2 is connected to the 120mono camera, but returns if PHD 2 is stopped.
The problem is real and not caused by old versions of other software.
I also wonder about the drivers in the current pack, because after I installed it Device manager shows the 120 and the 290 using the same driver-- ZWO 1.0.0.5 (11/25/2014). That might be intent but a 2014 date seems wrong for a 2017 release.
Please read Robin's post about this problem at https://forums.sharpcap.co.uk/viewtopic.php?f=5&t=59https://forums.sharpcap.co.uk/viewtopic.php?f=5&t=59
I am familiar with the advice given here against using hubs or longer cables with ZWO USB 3 cameras. However after reading comments elsewhere suggesting that the oem cables are a problem, I switched to an aftermarket cable and found I could connect any three of the four USB devices at the scope via a USB 3 hub and cable. For example two USB 3 cameras and the USB to serial adapter for mount control.
Then after the 120mono was switched to the current driver this fails also.
If there is a limitation in the ZWO hardware for example in the chipset used or in the driver or a combination of both that precludes using sharing a USB port, or precludes them from using a longer than supplied cable or both, it might avoid customer issues if ZWO clearly stated this in the product descriptions.  This is a serious limit on usability because it my require locating the PC at the mount.
I have a permanent setup, with a work station a few feet away from the mount. It would be unsafe and impractical to run three or four 2m USB 3 cables to the workstation.
If this limitation is fixed and had I known about it before hand I would have had the option to try and accommodate it or consider another option. But any workaround could be much more expensive.
I am very happy with the performance of the three ZWO cameras that I have, but not nearly as pleased with this USB 3 or driver problem. If I was rating the cameras I would have to knock off one star. Others may not see this as a problem, but clearly at least a few of us do.
