This is from a stack of 65 images all exposed for 60 seconds each.
No OAG, Orion mini deluxe guide scope with an asi 120mm-s guide camera.
Also using the ZWO electronic filter wheel, but all these images were taken with the Luminance filter only. The moon was below the horizon for these images. I used a master luminance flat made from 25 flats using a light box, exposures had to be very fast at 0.05 second exposures for flats. I could actually use advice on the exposures for flats on this camera although this seemed as good as anything else I tried. One second for liuminance was way over saturated.
I used a master dark made from 25 dark exposures at 60 seconds each.
My bias was a master bias made from 100 bias frames.
The resized master flat is shown below in jpg format.
Thanks,
Randy
