After a few more failed tries to make the connection,,,, and after a rereading of the SGPro Manual I saw a note about the ASI Camera not appearing in the camera menu that I had not loaded the proper ASCOM Drivers for the camera .... I found those drivers on the ZWO s/w support URL and loaded them
and then reran SGPro and the camera and the filter wheel did appear in the respective equipment window.... and after setting up SGPro the Find and Focus command did grab and display a real image.... so the problem was basically a beginners woes sort of issue B Wallis
