Has anyone worked out what the best Convert Colour setting are for this camera using MaximDL? I thought about using the Nikon D7000 presets as this I believe has a similar chip. Also any advice on X Y Ofsets and R, G and B scaling values
the bayer pattern of ASI071MC is RGGB, so Xoffset and Yoffset are both 0.
Thanks for the info on x and y settings. Was I right to select the Nikon D700 as the preset or is there a better choice?
almw59 wrote:Thanks for the info on x and y settings. Was I right to select the Nikon D700 as the preset or is there a better choice?
no, you need to choose "generic RGB bayer"
