Hello
I have purchased the ASI-1600mm-c (new version). There is a screw for the desiccant tube. Under this screw is a o-ring which causes that the screw is about 1mm over the surface of the camera.
That means that the holder ring cannot be used.
After I had removed the o-ring, the screw ist flat to the camera surface.
Question: Is this o-ring mandatory?
Thanks for your advice!
Ed
