Ive just got an ASI290MC hooked up with Firecapture. All seems to work OK, but my initial results werent great. I just want to make sure I have the basics correct for planetary ie Jupiter and grateful for any input.
I'm using Skywatcher 200PDS with powermate x5, so F25 approx.
As I understand it, gamma should be 50, and gain should be 350max. Exposure should be adjusted to get histo about 80%. Does that sound correct?
Some specific questions -
How do I switch form 10 bit to 12 bit, and which should I use?
Should I tick the 16 bit option?
Should I enable High speed and what does this actually do - maybe it switches from 10 to 12 bit?
I tried Ram buffer - this seems to work well, but will it compromise image quality?
Any other tips?
Many thanks!
